Spiral Kink does not effect Grass
When I select Spiral Kink, as in the video, my grass does nothing. It just stands up straight. How do I fix this?
  • Jonathan Lampel replied
    Hey Albert, this seems to be a weird quirk in Blender, discovered here: https://cgcookie.com/questions/5206
    If anyone else has an issue with the "Spiral" Setting not working, I've found a fix: 1. After changing "Hair Length" to "0.1" in tutorial, go to the top of your particle settings and check the "Advanced" box 2. Scroll down to your "Velocity" options and change the "Random" setting to "0.01" 3. Resume tutorial where you left off; You're good to go! Hope this helps!
  • heroxlegend replied
    Thanks that work !
