Fireflies & Reflections
I seem to be getting a lot of fireflies, did you have denoise  turned on? I don't want to whack the sample count up as it will take ages! Also I get a lot of reflections from the triangle which is quite distracting. Did you do anything to limit these?
  • Jeff Lange(jefe317) replied
    I didn't use denoise, but I remember bumping up the samples a bit when I rendered. Another option is to use the 'Clamp' option. It can be found in the render settings within the 'Sampling' panel.
