Bell cloth modifier not working
'm getting an odd result when applying the cloth modifier to the bell. I have attached a picture. It wrinkles about itself then eventually falls on to the bell and slides off! Not sure whats going on here!!!! I added a solidify modifier hoping it would solve the problem like with the tentacle and it didn't. A subsurface modifier gave slightly better results but still not correct! Any advice?
  • Andrew Elliott(aecs) replied
    Hoorah, it was the turbulence force field that was causing it, set it all to zero and it worked perfectly. Can I now delete the turbulence force field? I didn't see it mentioned in the video unless I missed it?
  • Kent Trammell replied
    Thanks for posting your solution, Andrew. No doubt other will find that helpful. Sure you can delete the turbulence field once you're satisfied with your simulation.
