What is the best method for unwrapping this hair and applying a texture after if course converting to a mesh object?
  • Kent Trammell replied
    Since they're all tubes, I would cut a seam down the length of the tube for a simple unwrap. Then you could copy the UV's of that mesh tube to all mesh tubes that share the same geometry (which they all should unless you altered the curve's settings before converting to mesh).
  • Curious (golden-kitty) replied
    Thanks that is what did:)
