the texture only stretches on the sides that the scale is on how do i get around this it seems like a fundamental problem
posted to: Brushed Metal
  • Kent Trammell replied
    The cube is not an ideal object because it's surfaces face the exact same direction as the mapping axes. But you can change the Z-rotate value to 45 to remedy this.
