Vertexes Twisted up when I bridged edge loops?
I believe my mesh is confused on which vertexes it's supposed to bridge with when I try to bridge the bottom half of the handle with the top half. Is this my own fault in the mesh? and how do I fix it?
  • Jonathan Lampel replied
    Hey ttacocat , there is a twist setting in the operator panel (F6) that will allow you to correct any weirdness that Blender comes up with. If that doesn't help, then you likely have a different number of vertices on the top than on the bottom.
