VonnBott Properties - can't find? Which menu is it on? The script executed find (or it appeared to)
  • Wayne Dixon replied
    It is in the 'properties panel' of the 3dviewport (n)
    make sure you are not getting any errors in the info bar as soon as you open the file.
    ("reload trusted")
    And that you also have 'auto run python scripts' from the User Prefs> File
  • Joseph Stout(jdreams) replied
    next to global on the bottom where there are tick marks.  I show just the 1 tick indicating my vonbott is in the scene.
    I append the rig
    Nothing different happens
    Ok so you have linked in the character so make sure you create a proxy and select the actual rig (not the mesh)
    This will make a local copy of the armature, and the ui will show
    I open the python script in the text editor and load it :
    I click run script; no errors but it doesn't appear to do anything ...
    back in 3d view::UI doesn't come up still and no rig will allow me to move stomp around
    Have you read my reply?
    Create a proxy for the rig.
    Select the linked object.
    Then
    Ctrl+Alt+P > Type 'rig' (and choose the rig object)
    And violla, it will work.
    Wayne, sorry about all of the images but I am really interested in pursuing all of your courses and I feel like I've gotten so much so far...hopefully you can help me get on my feet.  Let me know if I appear to be doing something wrong ; or if I am using improper terminology.
    ahh I see, so when you say create a proxy....what hot key do I use?
    I swear I kept scanning your videos to see how to create the proxy but I couldn't find it...I know you say that in your video..I just couldn't figure out the hot key
    ahhh nice; It did work!  The UI menu is still not showing
    Pose mode.
    Wayne, Thank you so much.  I know that was painful lol  I wrote it all down and am putting it in my folder so I remember for now on.
    when you make the camera go downwards when you adjust it....what do you type?
