Are we allowed to use Vertex Paint Mode?
Or should we just apply solid color materials on a per-object basis? I don't believe we could use textures as that would involve UV unwrapping and hence entering Edit mode (unless one used generate UVs on the primitive at time of creation). Thanks!
  • Jonathan Lampel replied
    Hey Adam, no need to color the model at all, but if you do want to I would recommend doing it on a per-object basis. Good luck!
  • Adam Janz(copperplate) replied
    Thanks Jonathan for your reply! This was perhaps the most difficult exercise I've encountered yet... as Edit mode was forbidden! :-) I created a small outdoor deck using only Object mode, array modifiers, bevel modifiers, and 2 boolean modifiers to cut the front, bottom, top, and back of the stair supports. Created it all using real-world Imperial measurements... although the stairs are wider than normal at 6 feet. :-)
    https://cgcookie.com/exercise_submissions/14539
