About the selection in the last part
When doing the select similar by area at the end(6:35) to indent the seams I got a bit of an issue as it wasn't picking up some parts as intended so I had to waste time doing cleanup by hand.
I figured a more convenient way would've been to select by similar area the seams and then invert the selection. You might think than it would be the same but actually with the same threshold the seams come out perfectly clean while triangles need cleanup
  • Jonathan Lampel replied
    That sure works, great job problem solving!
  • mathewbeltran replied
    New ideas for Solving a problem for all individuals. Students of the World and essaywriter.org/report-writing-help are pushed for the mid of the plants for all ideal paths. Grant is filed or the help and curious options for the documentation for all elements for the changes for options.
