Is there an add-on or script to turn Edge and Face Info ON for all meshes in scene?
posted to: Units and Snapping
Or can it only be toggled individually? Thanks
  • Jonathan Lampel replied
    There's a somewhat hacky way to do it: select all meshes in object mode, enter edit mode on one of them, and hold Alt as you turn on the info. That will apply it to all selected objects. If you have Emulate 3 Button Mouse turned on in your user preferences, you'll need to disable that momentarily while you do this, since it overrides the Alt key.
  • Adam Janz(copperplate) replied
     Thanks for that helpful tip!
