I can not get the arms to move
I selected the bicep but I could not get it to rotate. I even tried going into the graph editor and editing the key frames of each axis on the arm individually but still had no luck. Below is a link to a picture of the setup I have in Blender. Any idea what I am doing wrong?
https://docs.google.com/presentation/d/e/2PACX-1vTpmOwcZrqTn-z80ksbQHaN4_9Pf8sXvhIBG79Iv9bjOCvRnZLVXBCRxoVmwZ4EXrCDMYeyu1jPo9iv/pub?start=false&loop=false&delayms=60000&slide=id.g3b0c458979_0_0
  • Wayne Dixon replied
    I reckon you have the arms set to IK.
  • Princess Ghastly(jasonatkinson) replied
    I'm having the same problem and I'm not set to IK. The rest of it has worked perfectly. Any other ideas?
    Going into the Vonn Bots Properties section and tweaking seems to fix.
    In your image I can see that the arms are set to IK:1.0
    That means the arms are in IK mode.
    The properties panel is where you set these properties and the Layers panel is where you turn on/off the visibility ;)
