Inset previous thickness not saved
every time I use the Inset tool, the thickness is reset to 0.01
why do I need to do to make sure it saves the previous setting?
  • Jonathan Lampel replied
    Hey Govy, I recently realized that it doesn't save your input if you just adjust with the mouse and confirm, but it does save it if you type it in manually after confirming.
  • govy govy(weirdrubikscube) replied
    well, I did input it manually and saved.
    is it perhaps a setting in the prefs that I don't have enabled ?
    Not that I can find, I think the difference is just between typing it manually or leaving it as-is after adjusting with the mouse.
