dir-x vrs open gl
Some use the direct-x others us the opengl.....
I was told that you use Direct-x if your GPU is nividia and Opengl if you GPU is AMD, otherwise, if you only use CPU (mine if faster then my GPU), just use direct-x.
Can you comment on this? Thanks
  • Jonathan Lampel replied
    Hey Chuck, so it actually isn't about which GPU you have, but which graphics processing convention that the program you render with uses. Blender uses OpenGL, so choose that when dealing with normal maps (that's the only thing it'll effect).
  • Chuck Shultz(fxswan) replied
    Thanks.....
