translucent lamps problem
Hi There.
Although I've managed to get lights work quite similarly as in exercise (night version), I am unable to achieve those nice translucent bright lamps. Can you give me a clue, please?
Thanks
Marek
  • Kent Trammell replied
    What happens when you raise the intensity of the lamps?
  • Marek Hollý(asil) replied
    Hi Kent
    Raising the intensity leads to more light in the room. Of course, the translucent effect is more visible, but still no match to the reference render. My guess - something has changed in the translucent shader itself from the blender version the tutorial was made (2.76) compared to version I am working in (2.79).
    Marek
    Are you using render clamp indirect/direct settings? That can clip out the bright areas when enabled.
