How exactly do I change the size of something in Object mode, like if I only wanted to make a primative smaller from one side, without going into edit mode?
  • Jonathan Lampel replied
    Make only one side smaller? I suppose you could use the Simple Deform modifier on Bend, but first I'd try to block out a similar shape without using anything fancy. It's OK if it doesn't look exactly right since the point is just to get used to object mode tools and blocking things out.
  • louis1lal replied
    You can change the origin of the object with the 3D cursor. Or you can change the size of the object in the properties panel by taping n on the keyboards. Finally, you can constraint to the x, y or z while doing the transform by typing x, y or z. I hope this is helping!
  • winston1 replied
    Brilliant!! Thank you
