When I hit the inset hotkey, it doesn't remember my previous settings, why is that?
  • Jonathan Lampel replied
    Hmm, I'm not sure why it wouldn't. If need be you could also use Shift+R to exactly repeat your last action.
  • Nicholas Yang(nyanginator) replied
    It doesn't remember last settings for me either (2.79b). Shift+R works fine, but not when following this video because there are other operations in between the two insets. F3 (Recent History) is an alternative to repeat an operation with settings, but if you repeat operations, it might be hard to distinguish which is which.
    Hey nnyanginator , since then I found that Blender only remembers the settings if you input the numbers manually after confirming the operation with the mouse. Hope that helps!
