When I make the select si,ilar:amount of adjacent faces, the etire sphere is selected EXCEPT for the pentagons. Why?
  • gfjarvis3 replied
    Look at the selection in your image. In order for the Select Similar to work your original selection in vertex mode must be the center of a pentagon. That vertex meets the criteria you are setting with Amount of Adjacent Faces.
    Hope this helps.
