Structural creases
posted to: Leather Collar
Hi, during the sculpting process some structural creases were made, specially in the crest to make the ilusion there are separate pieces. I think these are missing in the final result, how do you manage to make these?
EDIT: Screenshot added
  • Kent Trammell replied
    Hi Daniel - could you point out the area you're referencing via an image? (Screen shot with annotations would be ideal)
  • Daniel Mancebo(dani3) replied
    Hi Kent, maybe structural creases was not the right term, I was talking about construction lines. I've updated the question with the screenshot, I don't know if it can be seen clearly.
    Ah, you're right. I must have simply forgotten that detail along the way lol. Looking at the final model, it wouldn't be difficult to cut that detail via CTRL + R (Loop Cut & Slide) inside the selected chain of faces:
    In my case it's a bit more complicated. Specially in the forehead. Could these lines be done once the retopo is done?
    Or is it something you have to take in account beforehand?
    Heh, construction lines is what I meant too. Here's a quick and dirty (and incomplete) example of the workflow:
