I'm having trouble uploading my texture to SketchFab. I tried uploading the .blend file, and also tried a .zip file with a textures subdirectory which included my .png file. Neither unfortunately works. I'm only seeing a shiny blank object. Help!
Michelle
Hey Michelle, try changing the render settings from Lit to Shadeless in Sketchfab's 3D Settings. You can also manually add your image texture to the model in their Material Settings. Hope that helps!
Thank you, Jonathan! I did a bit more digging, and found out that I had to drag and drop my texture .png into the Material settings screen. I was looking for an upload field. I appreciate your help!
Michelle
