Latest version of this material
Could u do the same node setup Tutorial for the Blender 2.79 version please
  • Kent Trammell replied
    Does something in 2.79 make this different?
  • Robots Ate My Art replied
    hi, I'm following this lesson and can't achieve the same result. looks like the displacement isn't working the same way. I've downloaded the source files and the render result I've got is this:
    also, during the refractions and reflection lessons, you tell about mixing the glass BSDF and the Refraction BSDF because of the render time, but I tested and got better results with only the Refraction BSDF (less noise and rendering time: 37 seconds VS 1:06 minutes)
    I think that is the Why he is asking for an update. And I would be glad to see one as well.
    vvarunsekar @senhorempada Ah ok, yes they've since changed the location of the displacement settings. See if the answer in this question solves it for you.
    I think yes, now is a matter of changing the values for a good result
    Yep, that looks like correct displacement! 👍
