Can't see edges very well.
Now I'm sure I'm not the only one who has some issues with seeing meshes through the sculpt. Following this tutorial, I see that the shrinkwrap modifier does not use the offset addition. I did change my clip start in the view panel to 0.010 but it didn't fix that issue. Tried going lower and that still didn't help. I also tried changing the display type in the object panel to wire and add x-ray but x-ray isn't working the way I want or the way the tutorial shows.
Did I miss an important part? What can I do to fix this? Any help is greatly appreciated!
  • Kent Trammell replied
    Unfortunately the blender devs changed the way the clip feature works in 2.78. A bummed me tweeted about it when I realized the change.
    Whenever I do a lot of retopology, I simply open my .blend file with 2.77 and retopo with the former functionality. Then when it's done, I'll hop back over to the newest version.
    Sorry for the confusion!
  • Colin Stein(colinstein) replied
    Aw shucks, thanks. Downloaded 2.77 so I'll keep that version on hand. Hopefully they'll change/fix it back in.
