Where is "Cycles Hair Rendering" Tab??
Hey Kent, I've enabled "Experimental" Feature Set. But I can't find the Cycles Hair Rendering tab, which prohibits me from being able to smooth my lappets' curves with "Smooth Curves" causing the strands to look sharp and jagged. What now? (Man, why do the devs keep removing perfectly working and useful features like this? Or did they move it somewhere else?)
  • Kent Trammell replied
    You just need a hair emitter on an object and enable the Cycles render engine. With those being true, the Cycles Hair Settings will appear at the bottom of the particles settings tab.
