Exporting the video
posted to: Arcing Ball Bounce
Once I click the opengl render, a .py video is exported to the multi ball folder and youtube does not support this file type. How could I remedy this issue?
  • Wayne Dixon replied
    .py is the extension for a python script. (this is the UI script file, not a video)
    Check your output settings.
    When you click the 'clapper button' to render the viewport.
    It will use the render settings.
    You can see here that the 'output' will render a .mp4 file to the '//render/' folder (which means it will create a folder in the current directory called 'render' and stick the output in there)
    Those settings should work fine for you.
