cloth simulation pinning fail
Hi, sorry for interrupt, but Im facing some problem, When I run the cloth simulation, it is working normally, but when I combine with pinningit started to become weird (as pic showed).I set the pants as collision, is it because some of the settings I set wrong?
  • Kent Trammell replied
    Does the non-pinned cloth push away from the pants quickly when simming?
  • Ang Kok Hoe(kokhoe20) replied
    Hi Mr. Trammell, thanks for reply, this is how it happen
    I try to adjust the Cloth collision's distance option from 0.015 to 0.001, it seems better  but when it pinned too close to the collision object, the same problem will happen
    but when it pinned too close to the collision object, the same problem as 1st video will happen
    For some reason your videos aren't loading for me..But it sounds like there might be a scale issue. For example, if your objects are the size of ants, the simulation settings won't behave the same as if your objects were the size of humans.
    Could you attach your .blend file? I'd like to take a closer look at your scene.
    Mr. Trammell, sorry for late reply because I'm from Malaysia and sorry for my poor english as well.
    The blender. file is attached in this message, google drive blender file
    Beside the pinning problem, can I ask for advice bout how this character looks like and how to improve it?
    Really thanks for your help. I really enjoy the videos that you share.
    Wish you Happy New Year in advance
    Sorry for the delay. I can't seem to figure out what's cause that weird bunching at the top. I'm not sure I've ever seen something like that. Done plenty of cloth sim, but that's bizarre.
    I don't know what to tell you..I'm stumped 🤯
