I've some problem applying "with automatic weights" in object mode....
Hi,
 If I follow the tutorial, Ihave some problem because if i move the child bone the arm moves in a really weird way...
To obtain your results, I need to apply "with automatic weights" in pose mode....If i do that, everything works fine....(i'm using Blender 2.79)
Is that normal?
Thanks
Arian
  • Kent Trammell replied
    Pose mode is meant to move child bones and deform meshes as desired. Rotating in object mode means the entire rig is being rotated instead of a single bone.
