Why I see only wireframe?
posted to: Armature Edit Mode
with 2.79, I opened the file below, and saw only wire frame. It's not wire frame mode.
in cycle render mode, the skin adapted properly.
fundamentals-of-rigging_chapter2_lesson3_baker-skeleton.blend
It's not a big problem here, because I can load lesson4-5 version and delete the rig and start new one.
  • duketogo replied
    I found solution..
    properties -> Object ->Display -> Maximum Draw Type -> textured or wire
  • Kent Trammell replied
    Thanks for sharing the solution you found!
  • Joseph Stout(jdreams) replied
    6:01 in the Video explains exactly what duketogo describes above (Just in case you need to watch it demonstrated via video; that typically helps me)
