When I do "Select sharp edges" it appears that almost 100% of my edges are selected, which can't be right. Any tips?
posted to: UV Unwrapping pt. I
  • Suchaaver Chahal(minifigmaster125) replied
    Check that, I figured it out. If you are in vertex mode it selects all the vertices on the sharp edges, which then highlights all the edges, even if they technically weren't intended. Using edge mode solves the problem.
  • Jonathan Lampel replied
    Hey Suchaaver, that's happening because you're in vertex select mode, so any edges between sharp edges are also selected if the vertices are connected. Switch to edge select and you should be good to go!
    Just saw you already found that. Keep it up, it's looking great so far 👍
