So is it generally discouraged to make Normal Maps from high poly models using proximity loops?
Like, is that whole workflow out the door if you're making game models?
  • Jonathan Lampel replied
    You can definitely still use proximity loops if you'd like (since a bevel is essentially just proximity loops on both sides), just be sure that your flat faces have their edges marked as sharp so that the shading will be correct.
