What about NormalMap?
hey man, I was wondering, is that possible, using this method, to export the normalmap?
  • Kent Trammell replied
    Yes, you can convert the greyscale bump I generated into a normal map.
  • Chuck Shultz(fxswan) replied
    Once converted into mesh, the hair is not appear to be subject to wind forces. What would you recommend if you want the final product to show hair movement/bounce with head movement or wind effect?
    Thanks
    Once converted into mesh, the hair is not appear to be subject to wind forces. What would you recommend if you want the final product to show hair movement/bounce with head movement or wind effect? ( am asking hair stands and the end of the shoulders, etc)
    Thanks
  • Sara (Starry) (starry) replied
    Hi Chuck,
    Maybe you could try adding a cloth modifier to your finished hair cards?  That should interact with wind and if you fiddle with the cloth settings you should get something pretty good...
    ty
