Hi there, when I downloaded the Raw Mocap Data for Mecanim, The file : DefaultAvatar does not exist? Only the DefaultAvata...
posted to: Humanoid Rig Setup
Hi there, when I downloaded the Raw Mocap Data for Mecanim, The file : DefaultAvatar does not exist? Only the DefaultAvata.fbm, Materials and Animations was there on the downloaded file. Help and thanks in advance
  • keiko replied
    Whoops sorry, it was there, the file just loaded last when I open it.
    Glad you found it. To clarify the avatar is created when you setup the humanoid rig. So if you had your own humanoid character, when you set it to use the humanoid rig it will create the avatar for that character which essentially is the rig Unity created based off that character.
