Fill problem
I can't seem to connect the vertices at the top part of the console
Reply
  • Peter Unknown(NachoSheezz) replied
    This what happens when I shift select 2 vertices and hit F, it automatically selects other vertices after and fills something else
  • Grady Pruitt(gradyp) replied
    F to fill can be a little finicky at times... particularly if it can't figure out where you're trying to fill to.  When all else fails, can select the verts you want to fill. Also, when using F to fill, it helps to have the cursor on the side you want to fill towards.
    2 loves
  • Martin Bergwerf replied
    Solution
    Hi Peter,
    In every case I've seen, when F doesn't behave the way you expect, the Selection is different from what you think it is. In your case, I highly suspect that you have double Vertices (very likely in combination with inconsistent Normals).
    The solution is, (in Edit Mode): A (to Select everything) and then M . Merge > By Distance, (immediately) followed by SHIFT+N. But before you try Filling again, make sure that both Meshes are part of the same Object (they might be, but really make sure they are!). If they are not, switch to Object Mode and then CTRL+J to combine (Join) them into a single Object.
    2 loves
    Oh, and also see if you have anthing Hidden in Edit Mode: ALT+H to Un-hide.
    2 loves
    @Martin Bergwerf thank you so much! It worked!
