Different result from the tutorial when using Inset Boundary (17:40)
posted to: Modeling the Body
Hi,
I'm following the tutorial, and I'm referring to 17:40 in the video.
When the instructor presses I and then B (Boundary), the inset works correctly and the geometry stays clean.
Instructor's result:
When I follow the exact same steps, pressing I works fine. However, as soon as I press B, the left side of the inset starts overlapping/intersecting.
My result:
Could you please let me know what I'm doing differently or if there's an issue with my topology?
Reply
  • Martin Bergwerf replied
    Hi Bsam,
    There is probably an issue with your Topology.
    The usual suspects are 'double Vertices' and/or inconsistent Normals.
    Go back to before the Inset and Select All with A and then M > Merge > By Distance, directly followed by SHIFT+N (to fix the Normals).Then try again.
    Let us know if it still doesn't have the desired result.
    2 loves
  • Bsam F(Bevo) replied
    You're a legend 👑
    That fixed it Turns out I had 3 duplicate vertices. I never would've thought to check that.
    Thanks a lot for your help I really appreciate it
