Honey Jar Modelling clarification?
Question Modeling
I'm loving the honey jar video recently released, and seeing the whole concept to completion is a wonderfully helpful demonstration of the pipeline process!
Can someone please help me understand the benefit/use of the edge-split modifier for the cork? I accidentally removed it whilst attempting my own version, and yet the end result appears identical... 🤷‍♂️ thanks in advance!
Reply
    I haven't watched this yet, but the edge split modifier is an old school way of dealing with mixed flat and smooth shading. The same thing can now be done with the auto-smooth geonode Modifier or using custom normals. Shading uses vertex and face normals as part of their calculations. The edge split modifier creates 2 edges on top of each other. This causes a shift in the vertex normal. Basically two vertices at the same spot that now angle more towards the face that the edge is connected to, because it no longer connected to the other face and thus that face normal doesn't add to its calculations.
  • Martin Bergwerf replied
    In general, if the end result is good, or identical with a Tutorial, even if you've done something differently, there is absolutely nothing to worry about.
    There are always many ways to do something and not every detail in a workflow is essential. Sometimes, you see someone zero-ing out the Location of an Objectin the N-Panel, for instance, while you could also just use ALT+G, to Clear the Location.
    I also haven't watched this yet, but often these things are simply habits of doing something a certain way, even if it's not the 'best' way, it gets the job done.
    But I'll go and watch the Honey Jar and see if there is something more to the use of the Edge Split in this case.
    2 loves
    Hm,
    Well in this case, the Edge Split Modifier with its default Threshold Angle of 30° does nothing, because after the Bevel Modifier, there are no Angles greater than 30° left.
    We''l have to ask Kenny what he was trying to achieve here, because if the Modifier would have actually Split some Edges, then the Subdivision Surface Modifier after that, would have smoothed out single Faces, creating holes in the cork. Something like this:
    and I can't imagine, that that would have been the intention.
    But then again, Kenny is more specialized in Physics Simulations than in Modeling.
