Question about Curve direction...
posted to: Working with Curves
Could you please give me some examples of when switching part, or all of a curve's direction, is applicable in a best case usage scenario
Reply
  • Omar Domenech replied
    I'd say when for example you have a train cart that is following a curve that keeps it on track. And then the train guy is like ooops, I forgot my wife back at the station and he has to run the train backwards. So you switch the direction of the curve for the animation to change.
    2 loves
  • Martin Bergwerf replied
    Hi Charlie,
    You won't need that very often, but it's good to know, that you can do it.
    The main time when I used it, I think, is when using the Build Modifier on a Curve (for instance, when simulating writing text). If you find, after having spend a long time drawing the Curve and then find it's building back to front, Switching the Direction of the Curve is about the only way to fix that, as far as I know.
    When Animating an Object along a Path, you can use it, but then you could also just reverse the Animation (swap Keyframes).
    In for instance this Course: https://cgcookie.com/courses/bcity-building-a-procedural-city-generator-with-geometry-nodes
    the direction of Curves sometimes needed to be switched, but that was done inside Geometry Nodes.
  • Charlie Fisher(KingFisher78) replied
    Thanks guys, was just wondering as i had some idea's come forth... great examples :)
