32GB or 64GB System ram?
Anyone using more than 32GB system ram? I most just do GPU renders, nothing complex so far.
Current Build:
AMD Ryzen 7 5700X(8core/16Threads) 4.6Ghz
Kingston DDR4 32GB/3200Hz
Corsiar DDR4 32GB/3200Hz
Samsung 980 Pro 2TB M2
GTX 1660 Ti 6GB
Ive been running both these system ram kits on this same motherboard a year last April without issues.
Now heres my questions, I just got new GPU, (few months ago lol, have a  boy that just turned 1 year old) RTX 5050 8GB, and havent had the chance to replace ol trusty 1660 Ti. My original thoughts was tow keep the 1660Ti along side the new rtx 5050 8GB. Now Im 2nd guessing myself, if I should try using both GPU's in the same system?
I have enough parts, or almost to build a 2nd AM4 build. So would yall build two separate builds or run two GPU's in the same build? And last 64GB or 32GB on system ram do yall use?
thx, Shane
Reply
  • Grady Pruitt(gradyp) replied
    I'm not sure on the logistics of using 2 GPUs... If they're different brand cores (one AMD, one Intel), might possibly be some compatibility issues to make sure they could work together, but another thing to consider with 2 GPUs in the same system is to make sure your power supply is rated high enough to handle both.
    As far as RAM, I'd lean towards more is better, esp for long term planning, but that's me. :D System memory could handle a larger file that way.
    But I'd be curious to see what others say too.
  • Martin Bergwerf replied
    Also a consideration: 8GB VRAM is not that much; depending on what you use Blender for, you might run into situations, where you have to switch to CPU, because your GPU runs out of Memory. So it might be better to combine the 2, if possible.
    And I'd also go for 64 RAM,  but not with 2 different brands, if possible. Also prefer DDR5 over DDR4. That being said, Blender isn't very heavy on the System Memory these days, so 32GB might go a long way, depending on the complexity of your Scenes and what else you do (Browsers, for instance, can use up a lot of RAM).
