There looks to be a discrepancy with blender 5.1 for extrude.
At 10:40 when making the extrude I get a different result than the training.
You can see at the corners when pulling in I don't get the clipping I would expect but instead there are these triangles created. Also if I hold alt while dragging in the extrude I don't have some of the same alignment issues you later address.
I assume my best option is to try to merge these verts by hand?
Reply
  • Martin Bergwerf replied
    Solution
    Hi Josh FullStacking ,
    That has nothing to do with a difference between 4.2 and 5.1, but with you having made a (or more) mistake(s) along the way.
    Now I don't know exacvtly what you did, but if you, go back to just before the Extrude and then Select everything (with A) and M > Merge > By Distance.
    Then it should work fine.
    If you can't go back, you'll just have to fix them by hand, like you say.
    2 loves
    My first guess is that you are in edge select mode instead of face select. Also possibly double vertices?
  • Josh Chernoff(FullStacking) replied
    I tried to reproduce and indeed it must have been something I did along the way, not seeing the same effect the second time around.
    It's hard to reproduce, but it might be an unintentional ALT+V (Rip and Fill) on the corner Edges, before Extruding.
    TIL: There is a visual undo history in the edit menu. This is going in my quick favs.
    2 loves
    Oh cool! I didn't know that.
That course doesn't exist!
