Bump Node works differently after 4.5
Anyone know how to achieve the same bump effect after blender 4.5? Increasing filter width allows you to basically change how obvious the bump is in this case by adjusting width but the texture now copies onto the bumped surface making it less obvious..
Reply
  • Martin Bergwerf replied
    HI Sam,
    First of all, where are you (timestamp) in this Lesson.
    The Bump Node doesn't so much work differently, as it has one more control, that you can usually leave at its default of 0.1 (Only change it if it's necessary and you know what you're doing😉).
    I don't really understand what you mean, but maybe it's just that you need to change the Voronoi Texture to 2D, like Ducky does.
    Edit: to get the same result as before, the Filter Width should be set to 1.
    2 loves
