Vertex Bevel affecting Edge bevel
Question Modeling
Hey,
When I move my vertex bevel modifier above the edge bevel one, the bevels of the 4 out edges shrink. Even tho the bevel weight of the edges and vertex affected are set to 0.
Image Link
Blend file
Thanks for the support
Reply
  • Martin Bergwerf replied
    Hi SStoic ,
    From the image, I'd say it's the Clamp Overlap kicking in.
    Now let me look at the file...
    2 loves
    Solution
    Yes,
    It's the Clamping, but you can't just disable it. What you can do, is make the (Amount of the) Vertex Bevel smaller:
    That way this (Active, white) Vertex from the Vertex Bevel, doesn't prevent the Vertex from the Edge Bevel from 'going' up further:
    2 loves
  • Omar Domenech replied
    In case you are wondering, there are multiple ways of going about it, but since it's a beginner tutorial, JL goes the easiest route. So don't worry if you feel is a bit convoluted in the beginning, you'll get used to modeling bit by bit.
    2 loves
  • Stoic replied
    Thanks Martin and Omar, problem solved.
