Parent Switch - choose between integer and float
posted to: Parent Switch
In the IK FK Switch Community Discussion, there was a question about bool and float for the driver property.  For the parent switch,  are there any situations which float is used instead of integer?
Reply
  • Wayne Dixon replied
    Good question K-Chow.
    Parent switching and FK/FK switching are very similar but the difference is....
    IK/FK switching has 2 sets of controls that the DEF bones switch between.
    Parent switching has the same set of controls that switch what they are following.
    There is a benefit to having IK/FK switching as a float because you can switch over a few frames to make the switch seamless.
    If there are only 2 parent options, you could potentially do the same in some situations. But more often than not you won't be able to.
    There could be more than 2 parent options, or one of them might actually control another part of the rig (in the IK/FK switch both sets control the same part...potentially), or blending between the options will give you some really weird results.
    So Parent switching works best as a boolean.  IK/FK can work as a float.
    2 loves
