Multiple objects
Hello,
Just wondering if there is a difference between the First and Second objects that you link the empty to? Also, if we had 3 or more objects we wanted to dangle, do we have to add more empty objects? Kinda curious why it's only limited to 2 objects in the constraint settings
Reply
  • Martin Bergwerf replied
    Hi Jim,
    The order of the First and Second Object doesn't matter.
    It's an old system, that's probably why it's only limited to 2 Objects per Constraint.
    But there is a fast way to Add a Constraint between Rigid Bodies, that you can also use for more than 2 Objects (will prodsuce more than 1 Constraint):
    From the Object Menu:
    It will automatically Add the Empties which hold the Constraints and you can change the Constraint Type in the "Adjust Last Operations' pop up (or F9).
    2 loves
  • Jim Lee(slimjim) replied
    Oh wow that's cool, I'll make sure to note that down thank you!
That question can't be found!
