I have downloaded your version of the sculpt tool. However, when I draw a line and make a cut, the piece I cut off is not ...
I have downloaded your version of the sculpt tool. However, when I draw a line and make a cut, the piece I cut off is not deleted and my grease stroke remains. I can manually hit X and then delete the piece I just cut but my grease stroke remains. I have toggled the exact same settings as you showed in your video. Is there a newer version I should be using? What can I do to fix this?
  • sveg replied
    Hi, In the new Blender version the Grease Pencil data is attached to the scene instead of the object. You have to change this: 1. Press the "N" key to reveal the N-Key panel. 2. Under the "Grease Pencil" tab change the from "Scene" to "Object". Should work like in the video.
  • Keegan Keene(silver593) replied
    Ok I'll try this! I did not see this in the video it was a little fast. Thanks!
