i am trying to make hair using the path and circle object. in the path options i went to the bevel option, changed to object, then i selected the circle object but nothing happened. how can i fix this.
Is the Circle Object a Mesh, maybe?
It should be a Curve, or it won't work.
Otherwise, you really should give us some more information (again๐). Context, screenshots and so on.
Please read this Post: https://cgcookie.com/community/21510-advice-for-effective-q-aย
It works now! I was using circle from mesh. But I changed it to curves circle and it works. Thank you!๐
