Hand does not Rotate with Elbow_pole.L
At approximately 18.08 Minutes into the tutorial:
When you move the Elbow_pole.L up and down with G your arms DEF-Arm_Upper.L, DEF-Forearm.L and DEF-Hand.L all rotate.
When I move the Elbow_pole.L up and down with G only DEF-Arm_Upper.L and DEF-Forearm.L rotate, DEF-Hand.L doesn't rotate.
I can't figure out what I'm doing wrong.
Any suggestions where I went wrong?
Reply
  • Wayne Dixon replied
    Hey John,
    In the end you don't want the hand to rotate when the elbow moves. So it's possible that you have inadvertently already done something that I later do??
    It's impossible to tell without looking at your file, but I wouldn't worry about that.  Just keep going, if it's still a problem* when the arm is complete then check it against the finished rig.
    *it's not a problem at the moment
    2 loves
