Usesfulness
posted to: 14 Floor Constraint
You said in the video it wasnt used all that much, would you not use this all the time with the floor, to help the feet of the character not go through? or would you just do another thing for the floor?
Reply
    It's more common to use the shrink wrap Constraint. Floor constraint only works on a totally flat surface. Where shrink wrap can work on uneven surface.
  • Wayne Dixon replied
    Hi Neo,
    You might think that it would be better to add a floor constraint to stop the feet going through the floor, but there is a much easier way.
    It's called "The Animator".
    If they can't put the feet on the floor, that is 100% on them - not you as the rigger.
    But let's imagine for a second you did add a floor constraint on the feet of your character, and then you wanted to animated the character walking down the stairs.
    You would have your 2 feet controls + 2 floor controls to animate.  Which is more work in the end.
    So you might think your are doing the animator a favour, but really it's easier to keep it free on open.
    Where it is useful though is mechanical rigging.  In the OFF-ROAD course, there are special floor constraints on the tyres of the RC Car.  This is because the 'feet' of the 'character' should follow along with the main body of the car (not so in a normal character).
    In that course you will set up a system that uses controllable floor constraints and a shrink wrap constraint so the wheels always stay where you want them and making it easier for the animator (not harder)
    Hope that makes sense.
    2 loves
  • Neo Benavidez(t4nk3uster) replied
    gotcha, should half clarify because I'm doing this mainly as solo, so im gonna be the rigger and animator so thats why i had this question but that makes sense. Thank you for the clarification
