Extruding not working
posted to: Sidewalks (Part 2)
Sorry to bother you on this other part.  I’m currently following your tutorial, but when I extrude the faces of my roads in Edit Mode  the result doesn't look like yours. Instead of keeping the thickness and smooth corner transitions, my extrusions distort the layout. I used the same geometry and node setup as shown. Could this be related to the curve resolution, normals, or a missing modifier setting?
Reply
  • Xavier Le Bitouzé(Zouval) replied
  • M
    Mike Hodgetts replied
    Hard to tell exactly what the issue is without seeing the full nodetree - can you send a screenshot of your full nodes, or send me the file?
    2 loves
    Yes I can do that  here is my .blend file
  • M
    Found it! The Separate Geometry node in your Road Curves group is set to point - needs to be set to Edge.
    3 loves
    Thanks you! You are a real life savor 👍
    2 loves
