blender factory settings
I want to do a factory reset on Blender as I'm having performance issues in what should be simple things to do.
However I've got about a year or so's worth of preference changes made over this time to the point where I don't remember what is default blender, and what preferences are things I've changed.
Am I able to save my current preferences (addons included - maybe), do a factory reset, and then reload and compare the two to find the changes I want to make and/or revert?
Reply
  • Martin Bergwerf replied
    HI Harris,
    I think the easiest way, would be to have two Blender Versions open and Load Factory Settings in one of them and compare that with the other Version:
    Load Factory Settings is not permanent until you Save Startup File, by the way.
    2 loves
  • Omar Domenech replied
    I'd just start from scratch and little by little let my needs dictate what was important to me. So as I work I'll be like dangs I'm missing this stuff I used to do, it made my job easier, let me install it. And again as I work being like man this task is killing me... oh right I used to use this stuff, let me go get it. And little by little you'll get back the things you used the most without overloading everything with a bunch of stuff you're not sure you'll use.
    2 loves
  • Harris Clook(Yeehawcowboyletsgo) replied
    Appreciate it, cheers guys!
