Ok so I got one more new problem and it is
Bevel modifier isnt working properly
Sometimes it works but sometimes it doesn't
The worked on console buttons but now its working in speaker edge
It says 0 removed and after merging them by distance the modifier still doesn't works
Hi Yousaf ysaf ,
Check the Scale and Dimensions of your Objects, if you compare the X-Location of the Speaker Vertices with the Bevel Amount...
What do you mean Omar?
Your money in on the scale??
Control + A wont fix??
Then how it would be fixed, I am asking that
how your money is on the scale?
What you tryna say?
Kindly explain it, if I am misunderstanding
