Adding faces between speakers and main body
I don't usually like to ask for help, but this has been bugging me for a while, and I can't figure out how to fix it. I'm having trouble creating a face between the sides of the speakers and that of the main body, around minute 16:40, for reference. When I select the vertices and press F or add faces in the program, it creates an extra face in the wrong place. When I looked into it, I concluded that it could be an issue with some doubling of vertices, and since it is mirrored, this problem occurs on both. I am unsure how to fix this problem. I'm not entirely confident in this as I have tried to merge everything by distance, and no vertices were removed, but I haven't found a decent solution after researching. If there is an explanation as to why this might be happening and how I might be able to fix it, that would be great. Sorry for the long explanation.
Reply
  • Omar Domenech replied
    Seems like you have rouge edges. Go into edge mode an select those edges and delete them. Then try selecting those vertices and hit F and it should create a quad.
  • Martin Bergwerf replied
    Hi G C,
    Your Speaker and Console are 2 separate Objects:
    Β and you cannot Connect Vertices of one Object with Vertices of another.
    In Object Mode, Select the Speaker and then SHIFT+Select the Console and CTRL+J to join them into 1 Object. (Probably need to Apply the Mirror Modifier first.)
    2 loves
    Ah yes if they are two separate objects then forget everything I said.
  • G C(R.D) replied
    Thanks so much. This helped a lot and made me learn something new. CTR-J didn't work for some reason, but I just used the manual button, and it worked great.
    • πŸ‘
