Bevel causing clipping issues on my model
I was following the course till the end of the video then I noticed my model was see through and clipping on certain parts of the edges. Can anyone help me fix this issue?Β
Reply
  • Im3DLia replied
  • Martin Bergwerf replied
    Solution
    Hi Arthur @ImArtie ,
    First of all, switch to Edit Mode and Select everything (with A) and then M > Merge > By Distance (just to be sure) and then (with everything still Selected) SHIFT+N, to re-calculate the Normals.
    After that, report back to us. (Hopefully this already solves the issues.)
    2 loves
  • Im3DLia replied
    Instant fix thank you so much!
    • πŸ‘
  • Im3DLia replied
    I also have this issue Im assuming it has something to do with my vertex placement ?
    Solution
    That might indeed be the case, Arthur, but I'm not sure; go into Vertex Select Mode and try moving that Vertex around a bit, see what happens.
    It could also be helpful to toggle the Edit Mode Visibility of the Bevel Modifier on and off with this button:
    2 loves
  • Im3DLia replied
    Thank you again for the help the issue has been resolved! I ended up merging the vertices together.025-01-27 033449.png
    • πŸ‘Great!
That course doesn't exist!
