Hello, despite my computer being quite good, Blender has become very slow. I did some research and found out that I need to apply the Booleans. However, when I applied them, I didn’t get the correct result. What do you think might be the reason for this?
Hello. Can you post some screenshots? Applying the boolean shouldn't be an issue, you can let them be in case you want to modify things. The model and the holes shouldn't be enough to bog down things so much, so perhaps you have too much geometry or you're using too many SubD levels? Perhaps you can upload your file so we can take a look and see how our computers handle it.
